10-12-2007 03:40 AM
10-12-2007 06:31 PM
10-24-2007 04:42 AM
Hi Gerardo,
just to better clarify what i wanted to do:
1. I have an analogue signal as input. its a 1Hz square pulse with Amplitude 5v.
2. This is the signal source that should hardtrigger an analogue output with my software-defined pulse pattern
3. The analogue output rate is not important, it should start when triggered to start and stopped when there is no trigger
Does it clarify things?
Regarding your AI example
The example you've attached is for AI reading not for AO, but i tried it and it did not showed anything on the graph..
let me see that i got things right:
1. I have hardwired the same pulse from (1) above to PFI0
2. I have wrote PFI0 as the trigger source
3. AI1 as the AI channel to display the triggered acquire data
Was i correct?
Thanks!
10-25-2007 02:42 PM
10-27-2007 01:53 PM
10-29-2007 11:51 AM
10-30-2007 03:36 AM
10-30-2007 08:40 AM
10-30-2007 10:31 AM
Hi Gerardo,
to the best of my recollection, i belive that on one of the posts, Raajit mentioned something about an example of Generate N updates Trig E series.
I am connecting my signal to the rising time of the PFI0 and there is a finite elements created by the AO start.
When using AO start in finite number of updates, it was written (in the help files of AO start) that AO wait should be used in order to make sure that the AO generation action is completed. hence i wrote that the error occured between AO start and AO wait
10-31-2007 11:07 AM
