Retrieving the information from a yokogawa gp20
I am trying to access and retrieve information from the Yokogawa GP 20 via labview and I'm not sure how to get started. Like how do I connect labview to my yokogawa? Do I use a static IP? And should I use Labview VISA to communicate to the instrument?
Any help would be appreciated thanks
(2,595 Views)
Additionally how do I find the scpi commands for the gp20? I didn't find anything on the instrumentation manuals
(2,589 Views)
National Instruments has a LabVIEW "driver" available for download for your instrument
Models Supported by this Driver
Models Tested? Description
GM10   Paperless recorder
GP10   Paperless recorder
GP20   Paperless recorder
GX10   Paperless recorder
GX20   Paperless recorder
=== Engineer Ambiguously ===
(2,551 Views)
Which manual?
This one appears to be chock full of commands:
https://web-material3.yokogawa.com/IM04L51B01-17EN.pdf
(Not SCPI, though.)
To use VISA, follow this set of instructions:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3gXCAQ&l=en-US
You'll need the "raw socket" option probably.  Note that in the PDF I linked, the port you'll need to enter is 34434 by default.
(2,524 Views)
You know the Labview instrument drivers usually comes with some sample code to get you started.
Anyway if that device is LXI compatible (and most instruments with Ethernet communications are) then setting it up in NI-Max (Measurement and Automation Explorer) and using it in LabVIEW is literally a piece of cake.
Accessing an LXI device through VISA is no different than accessing any other instrument on any other interface using VISA.
(2,511 Views)
Hello, I also have problems to read data from a Yokogawa GP10.
The temperature recorder is connected via Ehternet. VISA 5.4 is installed.
With the help of NI-MAX, the recorder is aswering but when i try one of the examples there is a problem with the initialization.
Is ist necessary to have a user with ID and Password?
Thanks for your Answer.
(2,265 Views)
