Hi Steve,
I have run your VI and have no problem picking up the SCXI modules, I can't find the SCXI chassis I am using as these are dumb devices.
Some SCXI modules do not have the onboard eeprom to give the system details about themselves, that is why the SCXI autodetection utility in MAX does not always work and you have to add some modules manually.
The only other suggestion I have is to make sure you have setup the SCXI portion of your PXI chassis in MAX, if the autodetection feature finde the modulesso should your program.
JamesC
NIUK and Ireland
Message Edited by JamesC on 03-13-2006 05:25 PM
