Restart VI on serial communication failure
Attached is a simple VI which is used to transmit the string 'Read' through the PC serial port & receive a 20 byte string in response.The Rx lamp indicates healthy communication.
I am using a USB to serial converter which sometimes latches up. Then the VI has to restarted to start communication once again.
I need to find a way to programmatically restart the VI in case of serial communication failure.
Can anyone give any ideas?
I am using LabVIEW 2015.
Thanks in advance.
Message 1 of 10
(1,400 Views)
Hi shantanu,
Idea:
  1. Check for serial communication errors.
  2. When an error occurs: close the COM port, wait for 2s, open the port again.
  3. back to item 1.
Message 2 of 10
(1,394 Views)
Thanks GerdW.
Then I need to have the VISA close VI, error handler VI & the VISA initialization VI inside the while loop isn't it?
Message 3 of 10
(1,384 Views)
Is there any way to programmatically restart the VI using state machine ?
I am not very familiar with state machines but I have read that it can be used under similar situations.
I'll try out your suggested method though.
Message 4 of 10
(1,382 Views)
Yes, a State Machine is exactly what you need here.  The basic idea is that you have specific states that do a single job.  For example, you may have "Initialize Port", "Read", "Error", "Close", and "Exit".  If the Read state detects an error, it should set the next state to run to be Close which will then set the next state to Initialize Port.  It is all about setting what to do next depending on whatever factors are involved.
Message 5 of 10
(1,338 Views)
Thanks.
I'll try to write it using state machines & post it here for your comments.
Message 6 of 10
(1,335 Views)
That USB to Serial converter doesn't happen to have a Prolific chipset in it? Years ago the market was flooded with USB-Serial adaptors made with counterfeit chipsets. Prolific released new drivers that could detect the counterfeits and disable them, which makes them appear to randomly lock up. No error is thrown by the Prolific driver, you just get a VISA timeout.
=== Engineer Ambiguously ===
Message 7 of 10
(1,310 Views)
I am using ATC-820
Message 8 of 10
(1,290 Views)
I am using ATC-820
The web page says they use FTDI chipset so it's probably not that.
Message 9 of 10
(1,284 Views)
I tried for a few days to develop a bulletproof state machine code but for the time being dedcided to use a Ethernet-to-RS485 converter to tide over the immediate issue of the USB-to-serial converter dropping off service in Windows.
Shall definitely rewrite using state machines to enrich my knowledge.
Message 10 of 10
(1,187 Views)
