Resistance vs Temperature vi for Lakeshore 335
I am (hopefully simply) looking to create a vi that reads and outputs the resistance vs temperature data from a Lakeshore 335 temperature controller attached to a closed cycle cryostat
(1,391 Views)
There is an instrument driver for this model, you can easily install it from the LabVIEW environment by going to Help >> Find Instrument Drivers and search by Manufacturer. The driver is installed with some examples that might be useful for you located at C:\Program Files (x86)\National Instruments\LabVIEW 2020\instr.lib\Lake Shore 335\Examples
You can use one of the examples as template and then add the functionality you need.
(1,367 Views)
Hello
I'm looking forward to connect my computer to the Lakeshore model 335 with usb interface. And I have downloaded the drivers from LabVIEW enviroment but suitable for GPIB interface. I'm confused about the difference between two visons of drivers. Are they different? Can I intermixed use them?
Thanks for your generous help.
(1,175 Views)
