Resetting elapsed time in a state machine
I'm working on a state machine which includes timed sub-routines that are triggered by Boolean controls. In plain English, the basic structure I have is: user presses button -> go to task 1 (state)-> perform task 1, has time elapsed? no -> go to task 1, has time elapsed? yes -> go to task 2 (state)...
The issue arises when I trigger the event a second time where the time aspect is essentially ignored since the time elapsed vi does not reset for all the tasks in the sequence. I created a simplified version of my state machine and managed to find a solution by using a shift register.
I am hoping there is a better and more elegant way!
In the simplified version, it's not a problem, but I already have 12 shift registers and I would prefer not to use another one if I can avoid it.
(2,888 Views)
Accepted by topic author aalansari
In my state machine, I usually have a shift register with a cluster of data in it. Then there may also be a shift register for the error wire and something else, but you should be able to get by with much fewer than 12.
(2,874 Views)
Good idea! This will definitely help!
(2,862 Views)
