Resetting an indicator after stop button pressed
Hello, I'd like to reset the "read string" indicator  to an empty string when I press the stop button.
Message 1 of 9
(6,672 Views)
This is a classic example where a state machine with a well written init-case makes the whole question obsolete......
Norbert
Expert: Geometry
Message 2 of 9
(6,669 Views)
You could also set it to an empty string when you start the VI.
Edit:  If I read the thread, I would have seen that Norbert already said this.  Smiley Very Happy
aputman
Message 3 of 9
(6,615 Views)
The problem is NOT your indicator, but the string stored in the feedback node. Just initialize the feedback node with an empty string and the contents will be cleared the next time you run the VI.
(also, your "write" button should be latch action, eliminating the local variable. The code would also be cleaner if you would replace the huge concatenate string on the left with a formatting statement. even better, create a string array and use "array to spreadsheet string" to create a space delimited string ending with a newline. Also, the use of "bytes at port" is typically an indication of a poor implementation)
Message 4 of 9
(6,601 Views)
Can be done in  two ways (making the Empty string as Default value and invoking Reinitialize to default value ) at the start and the same can be done after executing loop.
Message 5 of 9
(6,577 Views)
I need a help to automatically resetting an numeric indicator to zero after i press the stop button.
Message 6 of 9
(3,934 Views)
What is the purpose of Numeric Indicator?
Whether its used in single Loop/Multiple Loop?
Does your Logic has chance of Race Condition?
Have you tried something to achieve this?
Its always better to share the Module you tried and what it does..
My Assumption is you have an Numeric Indicator which needs to set as zero once the Loop stops on pressing Stop button So that next time when you run you will have Value 0 in the Indicator.
Make the Value to Zero and Make that as Default Value and always initialize with Default values .
Message 7 of 9
(3,912 Views)
See i am using serial communication (UART) and  getting 4 sensor temperature as a string output from uart for every 2 sec and then i used spread sheet string to array to separate each value and giving as an input to thermometer indicator if i stop the execution of the program the value should be set to zero.
I tried with the local variable. it is working. If any options is there let me know it will reduce the program size.
Message 8 of 9
(3,904 Views)
Hi Rajsakthi,
Using a local to set the value of an indicator might work, too...
What about using a Select node to output your "zero" values instead of the real UART reading upon your STOP condition?
Message 9 of 9
(3,901 Views)
