‎08-26-2026 08:31 AM
‎08-26-2026 08:37 AM
I have setup the LabVIEW environment in tool. It cause the font size in menu front panel small than before setting. But I don't know how to reset it back to default setup. Enclosed is captured imageSmall font size menu .png
‎08-26-2026 09:00 AM
Close LabVIEW, then find the relevant line in the labview.ini and delete it.
‎08-26-2026 09:11 AM - edited ‎08-26-2026 09:25 AM
Where labview.ini location? Is it in C:\Program Files (x86)\National Instruments\LabVIEW 2026
It was correct format font size before I go to LabVIEW tools/options... change some setup. After that the all the menu File Operate Tools Help became very small font size hard to read all the line.
‎08-26-2026 09:59 AM
I found it on root directory of LabVIEW 2026. I just copy the the LabVIEW.ini form other which is working right and over write the current file. It work as default now.
