Reset LabVIEW front panel menu bar font size to default
(912 Views)
I have setup the LabVIEW environment in tool. It cause the font size in menu front panel small than before setting. But I don't know how to reset it back to default setup. Enclosed is captured imageSmall font size menu .png
(908 Views)
Accepted by topic author HARRY_D
Close LabVIEW, then find the relevant line in the labview.ini and delete it.
(887 Views)
Where labview.ini location? Is it in C:\Program Files (x86)\National Instruments\LabVIEW 2026
It was correct format font size before I go to LabVIEW tools/options... change some setup. After that the all the menu File Operate Tools Help became very small font size hard to read all the line.
(879 Views)
I found it on root directory of LabVIEW 2026. I just copy the the LabVIEW.ini form other which is working right and over write the current file. It work as default now.
(863 Views)
