08-20-2018 02:13 PM
Hello, I wanted to get some input before I open a bug report. Is anyone else having issues with the "favorites" pallet in the block diagram pallet menu?
I am not sure if this is a unique bug related to adding my own toolbox to the block diagram pallet, so I wanted to post and see if anyone is able to replicate this issue. See video example here:
What is going on: When navigating the block diagram pallet menu with the ARROW KEYS (mouse does not seem to cause the same problem) LV2018.F1 crashes. Note that no LVfailurelog entry is created by this crash.
08-20-2018 06:56 PM
This doesn't happen to me, but looking at your icon it appears that you're using 64-bit LabVIEW. I'm using 32-bit. Can you confirm?
Just in general, when posting a bug of this nature (crashing) it's helpful to include:
The exact version of LabVIEW, including bit-ness and licensing level
Operating system info
PC specs
Any other installed NI programs or packages
08-21-2018 10:48 AM
@Kyle97330The exact version of LabVIEW, including bit-ness and licensing level
PC specs
I honestly forgot there even was a 32bit LV18 ¯\_(ツ)_/¯
I am running Windows 10 version 1803
Bug is recorded on a windows surface book 1
Other NI packages installed on this device:
Sorry to miss that obvious step!
08-21-2018 06:35 PM
PC specs
Really? NI's own recommendation is to use 32-bit unless you need the ability to use all of your PC's RAM in LabVIEW.
I mean, I'm still clueless as to why your favorites menu is broken, and if you need 64-bit then knowing that 32-bit is OK isn't helpful, but unlike many programs you shouldn't just install the version that matches your OS... it also needs to match any DLLS or toolkits you want to use as well.
08-22-2018 09:25 AM
@Kyle97330 wrote:
@szewczakReally? NI's own recommendation is to use 32-bit unless you need the ability to use all of your PC's RAM in LabVIEW [....] it also needs to match any DLLS or toolkits you want to use as well.
The Main use case I apply LV to is ML on acoustics and spooling out to 4GB+ of ram is a godsend. Also all the .dll/.so packages we write and rely on are x64. The reason I shrugged at the x86 is force of habit and assuming things were pushing in the x64 direction because of the depreciation of x86 architecture on LV-Linux over the past year.
