Reproduce wizard for DAQ-mx Synchronization modules (NI 9469)
I have 3 modules NI-9469 to synchronize the acquisition with 3 different cDAQ chassis. I would need to replicate the wizard in the NI MAX but I'm not able to find a couple of features.
The following figure shows the wizard I want to replicate:
In the daq-mx palette Advanced > System Setup > CDAQ sync, I've found some Vis to set connection between synchonization modules and to autodiscover connections but I'm not able to find:
- a way to verify connection
- a property node the return the list of all input and output synchnization ports (i.e. cDAQ6Mod8/port1 and cDAQ6Mod8/port0).
Can you help me?
(3,015 Views)
Hello  AC_85,
I point you out the following documents which talk about programmatically configure NI 9469 module and synchronization of multiple cDAQ chassis using that module:
https://forums.ni.com/t5/Example-Code/Synchronization-Options-for-Multiple-cDAQ-Chassis-With-the-NI/...
There are also example VIs in the attachments.
I hope that this could be helpfull.
Enrico
(2,939 Views)
