Report Generation Toolkit dependency broken after installing LabVIEW 2026 Q1
Thank you
Yes it is a problem with the exe.
I read the post about the paths but nothing has changed from when it worked to now it doesn't work except installing 2026.
Message 11 of 15
(1,007 Views)
If it is the RGT that is the issue, then the LV2026 installation moves it. Perhaps the code that generates the exe does not count the new location as part of the base and adds that randomly generated path when including the vi in the exe.
Perhaps it might be possible to copy the RTG files from a previous LV2024 installation and place them the right place, then refer directly to them in the project VIs. The old location would probably considered part of the basic LabVIEW installation.
Message 12 of 15
(996 Views)
I've use Package manager to remove RGT 2026 and guess what......
It's still available in the development environment.
This is so messed up.
At least now it is broken in the dev environment as well. Even though the vi's are there the application then gives a similar error to the exe.
Message 13 of 15
(984 Views)
I wasn't thinking about removing the LV2026 version of RGT. Keep it. Just find a copy of the LV2024 version of RTG and place it here: C:\Program Files (x86)\National Instruments\LabVIEW 2024\vi.lib\Utility\NIReport.llb. Then replace all your VI calls with direct links to these VIs. Perhaps that will force the exe builder to include them from the LV2024 vi.lib directory and the path will not be corrupted. Just an idea.
Message 14 of 15
(963 Views)
Hi Enthusiastic Tester
Thank you for your suggestion.
It seems to be working.
I took the excel folder from
C:\Program Files\NI\LVAddons\rgt\1\vi.lib\Utility\NIReport.llb\Excel
and copied it to
C:\Program Files\National Instruments\LabVIEW 2026\vi.lib\Utility\NIReport.llb
Then I added the LV_Excel.lvclass from
C:\Program Files\National Instruments\LabVIEW 2026\vi.lib\Utility\NIReport.llb\Excel\NI_Excel.lvclass
to my project.
In the build exe source files I added the lv_Excel.lvclass to always incuded
I built the EXE and ran it.
It opened the excel file as it should.
The other thing I did same as for the database toolkit I edited the json file
C:\Program Files\NI\LVAddons\rgt\1\lvaddoninfo.json
"AddonName": "rgt",
"ApiVersion": "v1",
"MinimumSupportedLVVersion": "24.0"
I changed the MinimumSupportedLVVersion to 24 from 26
Message 15 of 15
(940 Views)
