04-27-2006 09:11 AM
05-01-2006 06:15 AM
05-01-2006 08:25 AM
I have the vanilla install of Labview Development with the Labview 8.0.1 installed in the system. NI-Serial does not show up as a separate installation package. NI-Serial RT does show up in my additional installer. As far as I can tell, the Driver disk has NI-Serial 1.8 available. 3.0 seems only available on as a download but not in a form that is consistent with the driver disk (different extension). In addition, MAX is 4.0.2 on the NI-Serial 3.0 versus 4.0 on the Labview development.
So how would you install NI Serial to make it an option of the additional installer? How do you update the driver disk, provided you have a copy on the hard drive? Is there a special way to make a copy of the driver disk on hard drive since i have two driver disk?
05-02-2006 09:36 PM
05-03-2006 08:53 AM
05-03-2006 06:34 PM
You can, but you do not have to. It is an easy method of installing many drivers that you may need at once. You can choose not to install specific drivers from the device driver CD's if you do not have the hardware they pertain to or want to keep an older version of the driver. Otherwise, you can download the drivers separately from ni.com and install the driver that way. Windows will not recognize your hardware correctly until you have the driver for that hardware installed. You should install the drivers after installing LabVIEW so that the installer will automatically install support (the VIs) for the driver into LabVIEW.
05-04-2006 08:29 AM
It will not let me do it. All the drivers were installed during the installation of Labview. In fact, after the installation, they still pointed to the cdrom drive. The only device it did not point to is the Labview 8.0.1 run-time option. All the other items point to e:\. I have to admit, after the installation NI-Serial 8.0 it changed the pointer to the correct locattion.
Could it be that during the installation, when I started to select the devices I want, the installation procedure was not working to change the locations?
05-05-2006 02:24 PM
I don't understand what it won't let you do. Can you clarify that?
As default, the drivers will install from the device driver CD's during the installation of LabVIEW.
When you add additional installers to your application installer, it could ask you to insert the CD where you installed the specific driver in the first place. If you installed the drivers from a CD, you will see this message. The files necessary to create an additional installer are not cached on your computer after the installation is complete if you install from a CD. You will have to put the CD when you first create the installer in Application Builder. You should not have to have the CD when you then take that installer (that you created) to another computer.
However, if you copied the original driver installation files to your computer or installed the driver from files downloaded from ni.com, you may not see this pop-up. If the installation files are still in the same location that you installed the driver from, Application Builder will be able to find the source files (because they are still where they were).
05-08-2006 08:19 AM
05-08-2006 08:56 AM
Joseph Loo,
I'm going to venture a guess or two here, so I apologize in
advance if I have guessed wrong.
Is the device that you refer to that is requiring NI-Serial
a Modbus device? You mentioned you didn't even need the serial (just the TCP/IP)?
if that is the case you will be just fine if you don't install NI-Serial. You
can use the Modbus I/O Server with the project and as long as it is configured
for TCP/IP it will work just fine (it will not work over serial, and it will
raise an alarm if you configure it to do so).
If this doesn’t apply to you then please disregard.
-Lorenz
