Replace row of 2D array In Place
Hello community,
I want to replace an row in 2D-array (at specific row index) by using In Place Element Structure. The 2D array contains a lot of data, so I don't want to use the replace array subset.vi to prevent unnecessary copies.
Is there any way to use directly the Add Array Split / Replace Subarrays-functionality of In Place Element Structures? Normally Labview creates a copy of data if I use the replace array subset.vi, is this different by using it in In Place Element Structure?
The attachment shows my current solution.
(1,599 Views)
Highlighted
Replace array subset function will not make a copy the array. If you see a dot with the "Show Buffer Allocation" tool, it's because you are initializing the array as a constant (LabVIEW will not expect to modify it). Because you are using the replace array subset function so array has to be modified, LabVIEW will make a copy of the array. Change the dimension size input of the Initialize array function to a control and the dot(copy) will go away.
CLA
(1,583 Views)
