Replace each 0 and 1 in an array with n number of 0s and 1s
Hi , could you please help me with this. Lets say I have this array
01001
and I want to replace each 1 and 0 with 2  ( might be 10000)  number of0s and 1s. so the result is
0011000011
Could you please help me to implement this in LV . As mentioend I should be able to repeat the bits as many time as specified . 2 times or 100000 times
Message 1 of 8
(4,639 Views)
This sounds like homework, but i'll give you a hint -
You need to iterate through the array and create a seperate array based on the individual elements. To do that, you'll need a for loop, a case structure, initialize array, and build array.
You should be able to take it from here...
Philip
CLD
Message 2 of 8
(4,633 Views)
VI Attached.  Pretty easy logic to claim help  :[  I would suggest u to learn LabVIEW fundamentals. Read the help context and pratice with examples already shipped. 🙂
Message 3 of 8
(4,611 Views)
@p-rose wrote:
...To do that, you'll need a for loop, a case structure, initialize array, and build array.
Two for-loops will do, actually Smiley Tongue
Message 4 of 8
(4,597 Views)
Or you could just interleave the array with a copy of itself. See attachment.
Jarle Ekanger, MSc, PhD, CLD
Flow Design Bureau AS
- "The resistance of wires in LabVIEW is not dependent on their length."
Message 5 of 8
(4,587 Views)
I would use Initialize Array.
Message 6 of 8
(4,568 Views)
Or, if you want to be fancy, turn the digit array into a string, use search-and-replace (2X) to add your digits, then turn the resulting string back into a number array.
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 7 of 8
(4,550 Views)
Most cleaner and simple solution has been posted by crossrulz
Message 8 of 8
(4,528 Views)
