Reorder 2D array with new indexes
Contextualizing, in my software I have a translation search system, and I would like to search for the most similar phrases so that the user can see if the translation already exists, or at least a similar one so that he can reuse it. I'm using the Levenshtein Distance algorithm to check the closest sentences and according to this "note", I want to rearrange the array, from the lowest note to the highest
But I'm not able to do this efficiently, can you help me?
(662 Views)
In assumption that the Levenshtein works properly, may by you can simplify this up to the following:
(642 Views)
I've made a UTF-8 version of your "Levenshtein Distance.vi" and added it to my UTF-8 library.
(599 Views)
