07-07-2016 11:20 AM
Hello LabVIEW gurus....
I am working with LabVIEW 2014 SP1 32bits.
New project comming and i want to rename LVCLass from old project to new.
LVClass contains items from LabVIEW Packed Libraries. After renaming my LVClass, mr DVR contains new good links but it doesn't update into subVIs.
You can see details of my issue in the Word document attached.
To update the new DVR, i have created a constant from "New Data Value Reference" and replace it into my ClassControl.
Any hints will be apreciated.
BR,
Vincent
Solved! Go to Solution.
07-08-2016 02:30 AM
Any hints... 😞
07-08-2016 04:37 AM
Hello Vincent,
I have seen some dependencies issues between classes and packed library solved in 2015 SP1. Can you try with an update version of LabVIEW?
LabVIEW 2015 and 2015 SP1 Known Issues by Date
If this does not help, have you try rebuilding you packed library after you've changed the LVClass name?
Have a nice day!
Jun'
07-11-2016 04:28 AM
Hello Jun',
I did rebuild our Packed Libraries and all dependencies issues diseappears but bug still remain. Thanks for the link to know that bug has been solved in LV2015 !
BR,
Vincent
