Rename Controls and Indicators on Front Panel
I was wondering if there was a way to rename the controls and indicators on the front panel, or a clever way to alter them? For example, I want to put an ENUM control on the front panel and allow the user to make a product selection. Depending on the choice of the product, I would like to be able to update the controls/indicators associated with that part. Then, if the user decides to select a different part, those same controls/indicators would update again to reflect the new name change. Thanks!
(3,561 Views)
Hi Newbie,
      If you're interested in changing text on the Front Panel (FP) it's most common to create a string indicator (a text-box) above or beside the control being "labeled" and update that indicator as required.  Controls do have a "Caption" property, a FP text-label that can be made visible on the FP and which can be changed programmatically.  A control's Label - the label seen by default - cannot be changed programmatically.
Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,557 Views)
Thanks! I wasn't sure if renaming the label was possible or not. Renaming the caption instead works just as well 😃
(3,555 Views)
