Removing graphical glitch from fluctuating LED
Hi all,
I have an LED that I'm trying to have smoothly transition from green (#00FF00) to blue (#0000FF), and back. I have a working demo, but sometimes it experiences a graphical glitch where it blinks to different colors for an iteration. I've tried without success to reliably reproduce the glitch, but it seems to be ephemeral in nature. Any feedback would be tremendous.
Use a "milliseconds to wait" of 10-100ms to make the effect move quickly.
VI attached
Message 1 of 9
(3,638 Views)
I can see a glitch on my system also.
When I change it to use a colorbox, note I get rid of the boolean and its property node, I rarely see glitch.
See this thread for a round colorbox.
See attached.
mcduff
Message 2 of 9
(3,612 Views)
I also see the glitch. I reimplemented the fading algorithm to check if it was the boolean control and its properties at fault, but don't see a glitch with this version (attached). So there might be a problem with the fading algorithm you've implemented. My gut feel is a value of 256 is being fed into the RGB VI, which only accepts U8 (0-255).
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
Message 3 of 9
(3,556 Views)
Accepted by topic author ijustlovemath
Yeah, that was it. Change the 256 constant on that second quotient and remainder to 255 and it'll work without a glitch.
Message 4 of 9
(3,550 Views)
The 256 is the argument to a modulo VI, which only outputs 0-255. I'll look into your changes though! Thanks!
Message 5 of 9
(3,548 Views)
I don't have time to track it down further, but your second case structure is flipping your colors on the end points.
Message 6 of 9
(3,500 Views)
That's to achieve the reversal of direction in the color that I wanted.
Message 7 of 9
(3,482 Views)
It is not working as intended. It is flipping the values for one cycle. It reaches 255 Blue and 0 Green, the next cycle is 0 Blue, 255 Green, then the next cycle is 254 Blue, 1 Green. Try using a conditional break and highlight execution to see what it's doing.
Message 8 of 9
(3,475 Views)
I would recommend to just pre-calculate the entire color array (ramp up&down) once before the loop and thn just index into it. Much less code and fewer places for bugs to hide! 😉
(... and of course I would use a colorbox. It can be made to look exactly like an LED but the code is much simpler and you don't need any expensive property node. The color is the value!)
Message 9 of 9
(3,462 Views)
