Remove "zeros" form a txt file created by Labview
Hi Kabanga,
you can also use the code from the attached picture. It deletes the elements without using a loop. Smiley Happy It´s also possible with string.
Hope it helps. Mike
Message Edited by MikeS81 on 07-09-2008 03:03 PM
Message 11 of 13
(690 Views)
You didn't say exactly how you are saving the file.  If you are using a method which allows specification of a format string, use the underscore instead of a period in the width specifier to remove trailing zeroes (e.g. use %_5g instead of %.5g).
Message 12 of 13
(676 Views)
Hi Mike, Hi Gray,
thanks for your answers.
I've solved my problem yesterday using the solution proposed by Gerd.
Best regards
Kabanga
Message 13 of 13
(674 Views)
