Remove "zeros" form a txt file created by Labview
Hi all,
I got problems with a saved txt file and I hope somebody will me here.
I'm doing measurements and saving data in a txt file.
The data look as follow:  0.000000
                                        1.258766
                                        2.479566
My question is: how do I programatically  save these data without  "0.000000" so that the saved txt file looks like that: 1.258766
        2.479566
Thank you for your help
Best regards
Kabanga
Message 1 of 13
(4,209 Views)
Hi Kabanga,
well, usually this is a very nice tutorial questionSmiley Wink
One solution could be:
It's not very efficient, but works: In a first step the array is checked for zeros. In the FOR loop all those zeros are deleted, starting from the end of the array...
Message Edited by GerdW on 07-09-2008 11:57 AM
Message 2 of 13
(4,197 Views)
Check this http://forums.ni.com/ni/board/message?board.id=170&message.id=332775#M332775
Message 3 of 13
(4,194 Views)
Hi Kabanga,
you can trust muks as he now has a lot of experience on deleting items from arraysSmiley Very Happy
@muks:
Making the link as a real (clickable) link adds a lot of usabilitySmiley Wink
Message Edited by GerdW on 07-09-2008 12:09 PM
Message 4 of 13
(4,192 Views)
Hi guys,
thanks a lot !Smiley Happy
I'm gonna try it and will let you know the outcome.
Best regards
Kabanga
Message 5 of 13
(4,179 Views)
Right gerd.Thanx to you guys.
Message 6 of 13
(4,163 Views)
@muks:
yup will do so from my next post.
Message 7 of 13
(4,160 Views)
Hi Gerd,
I used your solution and it's working perfectly.
I don't see the "non efficiency" you were talking about. Could you give me more details on that point?
Thanks to you all guys your answers
Best regards
Kabanga
Message 8 of 13
(4,155 Views)
Hi Kabanga,
the non-efficiency comes into play when 1) working on big arrays and/or 2) deleting lots of zeros in the array.
1) You create a new boolean array with the comparison function. This creates a new buffer, which may lead to problems when memory is full...
2) When deleting array elements LabView has to create a new copy of the array. Same problem as in point 1, but here even more problematic as this occurs in a loop: worst case is to allocate a new buffer and copy array items with each iteration...
Message 9 of 13
(4,152 Views)
Hi Gerd,
I see now.....but I have  about 60 to 80 points to measure.
So I think it will work perfectly.
Bets regars
Kabanga
Message 10 of 13
(4,148 Views)
