07-05-2006 10:36 AM
07-05-2006 12:20 PM
07-06-2006 03:29 AM
Hi Dennis,
Yeah, the "undo" button return the instrument to the previous settings. Settings done manually or via Labview in my case.
07-06-2006 08:05 AM
07-06-2006 08:33 AM
Dear Dennis,
Your solution seems complex... In fact I just want to inhibit the default setup and not especially recover previous settings...
Do you know any function doing this ?
07-06-2006 08:52 AM
07-06-2006 10:21 AM
Dennis,
In fact I've just discovered the root of my issue : the previous acquisition is triggered in normal mode and so I just found the reset solution to remove this setting for the next acquisition.
So now when I remove the reset which put default setup in the 2nd VI, the same waveform than the previous VI is plotted because the second VI has kept the single shot configuration. So I have to find a way to set again the auto mode for this VI but the problem is this setting can be only changed in the "configure trigger.vi" function and I don't use this one in the 2nd VI...
I know it can be not so clear I hope you will understand what I mean...
Don't hesitate to ask for more explanations...
Thank you a lot
07-06-2006 10:38 AM
07-07-2006 05:39 AM
Hey Dennis,
I will try this, sorry if I surprise you with my issues which seem very easy to solve according to you
. Labview is always something new for me and I have to learn every day thanks to people like you
