Remebering settings in VI
Can anyone tell me what the trick is to having the settings not clear?
Example I have a bunch of test boxes and drop down choice menus.
When the VI is closed they revert to the first choice and the text boxes clear.
Im guessing this could be a property node thing but I can't seem to find it.
Thanks.
(2,483 Views)
Manually you can do it with Operate >> Make Current Values default. There are also invoke nodes you can use which are a little more complicated
(2,483 Views)
