Regeneration doesnt stop immediatly when stop called
I have a vi that writes 180 samples to an analog out and regenerates over and over. The problem that I'm having is when I call daqmx stop it doesn't stop immediately. It continues for a few more iterations of the 180 samples. I'm only writing 180 samples to the task once and there is nothing else in the vi.
(814 Views)
Please post your code so that we can understand better.
Besides, what is the model of the DAQ device? What is your update rate (sampling rate)?
https://tmesystems.net/
(808 Views)
I'll send code tomorrow and hardware.
However I'm sampling at 90 samples per second. I'm writing 180 samples so the put put should take 2 seconds.
When I call stop it takes like 4 seconds stop sometimes less sometimes more.
(786 Views)
