Reg Event Callback not working with .NET DLL written in F#
I have a .NET DLL written in F# which contains some CLR events.
While I can see a list of all events contained within a class in the DLL in the Reg Event Callback function, the events never cause the callback VI to be called.
I have written an example in C# where everything works fine (even with .NET 4.6). If I write the same functionality in F#, the events never appear to be received in LabView. With F# I have tried with .NET version 3.0-4.6.
What on earth could be the cause of this?
Message 1 of 10
(3,782 Views)
I am assuming that F# compiles the events to IL using add_* and remove_* methods to a private delegate and labels the methods with metadata describing them as an event. This is what the C# compiler does and I presume that F# "events" compile the same although I have never tried this.
Can you post your examples in C# and F#?
Message 2 of 10
(3,728 Views)
Sure. The [<CLIEvent>] attribute instructs the compiler to use the add_ and remove_.
The F# I have used
namespace LabViewEventTest.FSharp
type FSharpClass() =
    let someEvent = new Event<string>()
    [<CLIEvent>]
    member this.SomethingHappened = someEvent.Publish
    member this.ActionThatCausesEvent() =
        someEvent.Trigger("Something happened in F#")
The C#
    public class CSharpClass
        public event EventHandler<string> SomethingHappened;
        public void ActionThatCausesEvent()
            SomethingHappened?.Invoke(this, "Something happened in C#");
Message 3 of 10
(3,703 Views)
The F# I have used
    [<CLIEvent>]
The C#
Interesting. Presumably the metadata is intact; the CTS defines events and the event structure so I would be suprised if F# did not comply with this. Have you compared the IL?
Message 4 of 10
(3,661 Views)
The IL produced by F# and C#:
FSharpClass.add_SomethingHappened
IL_0000:  nop
IL_0001:  ldarg.0
IL_0002:  ldfld       Query_zfrpxs+FSharpClass.someEvent
IL_0007:  callvirt    Microsoft.FSharp.Control.FSharpEvent<System.String>.get_Publish
IL_000C:  ldarg.1
IL_000D:  tail.
IL_000F:  callvirt    Microsoft.FSharp.Control.IDelegateEvent<Microsoft.FSharp.Control.FSharpHandler<System.String>>.AddHandler
IL_0014:  ret
CSharpClass.add_SomethingHappened:
IL_0000:  ldarg.0
IL_0001:  ldfld       UserQuery+Class1.SomethingHappened
IL_0006:  stloc.0
IL_0007:  ldloc.0
IL_0008:  stloc.1
IL_0009:  ldloc.1
IL_000A:  ldarg.1
IL_000B:  call        System.Delegate.Combine
IL_0010:  castclass   System.EventHandler<System.String>
IL_0015:  stloc.2
IL_0016:  ldarg.0
IL_0017:  ldflda      UserQuery+Class1.SomethingHappened
IL_001C:  ldloc.2
IL_001D:  ldloc.1
IL_001E:  call        System.Threading.Interlocked.CompareExchange
IL_0023:  stloc.0
IL_0024:  ldloc.0
IL_0025:  ldloc.1
IL_0026:  ceq
IL_0028:  ldc.i4.0
IL_0029:  ceq
IL_002B:  stloc.3
IL_002C:  ldloc.3
IL_002D:  brtrue.s    IL_0007
IL_002F:  ret
But F# does indeed generate the add_ function.
Message 5 of 10
(3,624 Views)
What about the metadata tags information for both methods?
Message 6 of 10
(3,593 Views)
For F#:
	Method #2 (06000002)
		MethodName: add_SomethingHappened (06000002)
		Flags     : [Public] [HideBySig] [ReuseSlot] [SpecialName]  (00000886)
		RVA       : 0x00002068
		ImplFlags : [IL] [Managed]  (00000000)
		CallCnvntn: [DEFAULT]
		hasThis
		ReturnType: Void
		1 Arguments
			Argument #1:  GenericInst Class Microsoft.FSharp.Control.FSharpHandler`1< String>
		1 Parameters
			(1) ParamToken : (08000001) Name : handler flags: [none] (00000000)
And C#:
	Method #1 (06000001)
		MethodName: add_SomethingHappened (06000001)
		RVA       : 0x00002050
		hasThis
		ReturnType: Void
		1 Arguments
			Argument #1:  GenericInst Class System.EventHandler`1< String>
		1 Parameters
			(1) ParamToken : (08000001) Name : value flags: [none] (00000000)
		CustomAttribute #1 (0c000001)
			CustomAttribute Type: 0a00000f
			CustomAttributeName: System.Runtime.CompilerServices.CompilerGeneratedAttribute :: instance void .ctor()
			Length: 4
			Value : 01 00 00 00                                      >                <
			ctor args: ()
Message 7 of 10
(3,580 Views)
Rather than asking a bunch more questions, check out the metadata for the assembly, in particular the tables, for the following:  http://flylib.com/books/en/2.663.1.93/1/. Hopefully the content should line up.
Message 8 of 10
(3,574 Views)
I have now looked at the two sets of metadata, and I don't see any particular difference in what they describe. I wouldn't expect there to be, as the events work fine outside LabVIEW.
Message 9 of 10
(3,526 Views)
I have fixed this now.
It appears that for the event to work properly in LabVIEW it's necessary to use an custom delegate (or the EventHandler delegate).
let someEvent = new Event<EventHandler<string>, string>()
Message 10 of 10
(3,483 Views)
