08-08-2018 06:30 PM - edited 08-08-2018 06:31 PM
Is there a way to get the available COM ports in the VISA resource drop down to refresh when you click refresh? (in other words, to get the refresh button to work...) The only way I'm able to do it is by opening MAX each time I connect or remove a com port. I'm trying to build an executable so this is not a solution.
I did find the thread below and, as instructed, tried using a delay and then the "find resource" function, but the com ports still don't refresh. Is there a way I can wire the strings found by the 'find resource' function to the 'visa resource name' function? Since they're different data types, I'm not sure how to approach this. And if it matters, I'm using NXG. Thanks for your help!!!
08-09-2018 03:58 PM
Is it possible for you provide the code that you currently have right now? It might be a lot easier to give you tips if we can see your implementation.
