Reflection-like operations for VIs?
Good idea, Jarrod! That would have saved me about an hour of tedium.
- Steve.
Message 11 of 13
(988 Views)
P.S. If anyone updates or fixes this thing, please post the results and I'll do the same.
- Steve.
Message 12 of 13
(986 Views)
Hi Steve,
Some code tips:
If you want to have the last element in an array you can use 'Delete from array' with only the array input wired.
I would do the 'Empty Array' check at the end of the code in the while loop so you can eleminate the '=0' case.
If you really want to reinvent the wheel don't look at the Variant Probe, which will traverse everything traversable.
Ton
My LabVIEW Ideas
Message 13 of 13
(956 Views)
