Referencing files in a pull down menu
How do I create a pull down box that will reference files saved on the PC and open those files in a new window and can this pull down menu reference an entire directory to see what files are available?
(2,950 Views)
Here is a way to populate the list box with the files in a directory.
Message Edited by AndrewAlford on 11-16-2005 02:13 PM
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(2,944 Views)
Thanks.  Where did you find that string[ ] combo box?
(2,911 Views)
Hi
it is a property node of combo box.
Right click on combo box,  go to create , select property node
right click on property node that appears,  and go to properties and select strings[]
(2,904 Views)
