09-09-2005 06:01 PM
09-09-2005 07:18 PM
@Tek wrote:
I have created a VI that calls on another VI, but before it does, I want to check the "connections to clients" property node in VI being called. Is there a way to get information from the second VI's property node into the first VI?-Tek
Hi Tek,
I didn't find the "connections to clients" property you mention, but here's an example of how to retrieve properties from a VI without actuallly calling it.
Hope it helps!
Cheers
09-10-2005 01:28 PM
09-12-2005 04:30 PM
@tst wrote:
... an element called VI name, which is the same no matter which VI you call the property from.
... unless the VIs exist in different executables(?)
09-12-2005 04:48 PM
I doubt that is the case here, but maybe it will work if you open an application to the other app.
The help for the property says it's only available in the local LV, but I'm not sure if this applies to other applications or only to other computers.
09-13-2005 03:34 PM
I belive that this particular property can be called from any VI running and it
will return the same data.
From this property's help:
Returns an array of clusters containing connection information about the clients currently connected to the computer. Each cluster in the array contains the following elements:
Hope this helps,
Travis M
