Record a video with a camera and save it with a string as the name
Labview 2014 or 2022
I have a test vi that controls an actuator and records a feedback circuit.
It is also connected to an external indicator.
I need to take a video of the external indicator traveling through its range and save it under a specific name.
No processing, only record a set number of seconds then save file as.
Do I have to have the Vison add on to do this?
$5k is pretty steep for this single task.
If not I will setup a Raspi Cam and use GPIO pins to start stop.
Then use the file functions to move the file.
Was just hoping for a more ready made package.
(1,921 Views)
Unfortunately, you would need NI Vision Acquisition Software license to use NI-IMAQdx in order to capture image from non-NI camera.
Does My Camera Use NI-IMAQ, NI-IMAQdx or NI-IMAQ I/O?
Licensing NI Vision Software
Perhaps, you can use Python to control a webcam instead. See Python OpenCV: Capture Video from Camera
If you need to integrate this flow into LabVIEW, see Integrating Python Code in LabVIEW or Call Perl and Python Scripts from LabVIEW.
https://tmesystems.net/
(1,896 Views)
