Record 4 channel audio data to a single .wav file
i would like to know how i can write a 4 channel audio file into a .wav file?
i am recording the audio with PCI4461 and using 4 microphones (i.e. 4 channels).
(4,444 Views)
Sound File Write.vi accepts array of waveform as input data. Hence, you can write data from multiple channels into single wave file.
(4,443 Views)
hi, thanks for the reply!
my sub VI is currently as such, the only missing link i have is the input.
what function should i use to get input from the hardware?
(4,438 Views)
Instead of Acquire Sound Express VI, you should use DAQ Assistant to acquire data from your PCI 4461 card.
Chinmay Anand Misra
CLD
Technical Marketing Engineer
NI IndRA
(4,428 Views)
hi,
i have modified my VI and it is as such now.
How can i specifiy the folder to save it in a folder and also obatin the calibration factor for the wav file measured?
its kinda tricky for the calibration factor because its a 4 channel to single wav file type.
(4,413 Views)
You can directly wire the file path to the path input of the Sound File Write VI.
Chinmay Anand Misra
CLD
NI IndRA
(4,411 Views)
