Received Non-Fatal Error 5904: LV 7 during use of Labview application. What does this mean?
'Non-Fatal Error 5904'. LabView 7 application.  'Source: Comm Analyzer - CP Analog - Adjust Input Level.vi:CP RX Audio Muting.vi'  (MRTE 3.0 - Anritsu CDMA Test System)
/BCU002
Hardware Engineer•Design Reliability/Performance and Validation Group•Wavecom, Inc. - Research Triangle Park, N.C.•http://www.wavecom.com
(2,460 Views)
Bruce-
What are you doing when you get this error? Are you using the Comm Analyzer VI mentioned in the error? Has this worked before?
Xaq
(2,448 Views)
Xaq,
Here is the comment that was passed about the error source: Comm Analyzer - CP Analog - Adjust Input Level.vi:CP RX Audio Muting.vi
The application has been working fine for about 12 years, it continues to serve its purpose and the RF test equipment rack components are now obsoleted by newer models but it's still in weekly use and is kept calibrated annually but on occasion it unexpectedly throws an error like this while I'm using the test rack during a wireless RF parametrics test and it leaves me wondering if the root cause is the device under test or the test rack.  That's why I was hoping to find a detailed description about the error code.
/Bruce
/BCU002
(2,445 Views)
