06-25-2008 01:17 PM
06-26-2008
09:29 PM
- last edited on
05-09-2025
08:03 PM
by
Content Cleaner
Hey Mendeleev3104,
There is an attachment section at the bottom of the post when creating or editing a post. You might want to use that to attach a picture of your code.
None the less I will give a shot with some suggestions without viewing your code.
You should look into using shift registers along with the Insert Into Array.vi to build an array of numbers. A good source of information for shift registers can be found in the For Loop and While Loop Structures help.
Hopefully this helps!!
