11-18-2009 05:17 PM
I am trying to generate a digital ouput through NI pxi 6733 using the DAQ mx base programming in labview 8.6.
The problem is when I creat a digital ouput channel it showing an error and say not supported for this target.
I am not able to use the daq mx base I have all the softwares same version installed in HOST and TARGET.
I am using real time 8.6 and daq mx 8.9.5.
Thanks in advance.
Solved! Go to Solution.
11-19-2009 02:54 AM
Are you using DAQmx or DAQmx Base?
I asume its DAQmx, because DAQmx Base does not run on RT Targets.
Can you provide us with an error code?
Christian
11-19-2009 02:19 PM
Thank you very much Chris. I am actual using the DAQ mx base on RT which is not working, thank you very much for the reply
it helped me solving the issue.
Thanks and regards,
RAM
Graduate Student
Mississippi State University
11-20-2009 01:20 AM
You're welcome
