You VIs WILL run.
It is like this...
VIs developed in LV X.Y will run in LV X.Y.z and also vice-versa.
Also like this...
VIs developed in LV X.A will run in X.B (where A<B), but NOT vice-versa.
But your EXE will not run, unless you have got the compatible version (same as the LV dev version) of the LV run-time engine installed in the target machine.
- Partha ( CLD until Oct 2024 🙂 )
