07-26-2013 06:35 AM
I was wondering how I can implement the following method with Real-Time FIFO instead of "Chart History Length"
Solved! Go to Solution.
07-26-2013 07:14 AM
Here's NI whitepaper about RT FIFO. I would suggest u to read more specifically in first and third section (Using RT FIFO): http://www.ni.com/white-paper/3934/en/
07-26-2013 07:20 AM
Is there any way to read all the data inside a RT FIFO regardless of the size of the FIFO or the amount of data available in the FIFO?
I mean in every iteration of a loop, I want to read all the data in the RT FIFO and make the RT FIFO empty.
07-26-2013 07:21 AM
Yup. It uses two FIFO read nodes. The first one reads 0 elements, and the output for Element Remaining is wired to the second node's Number of Elements input. Voila, you check what's in the FIFO and pull everything out of it.
07-26-2013 07:23 AM
Got it.
07-27-2013 09:13 AM
So how does one read 0 elements from the FIFO? Are we discussing the RT FIFO Read (primitive) or the Shared Variable with RT enabled?
07-27-2013 09:23 AM
Actually, In every iteration of the loop, I will write 100 elements to the RT FIFO and then will read all the remaining elements from the RT FIFO.
When I write to the RT FIFO I can get the number of elements remaining in the RT FIFO, then I can wire the number of elements to my read function.
So, in my case I don't need to read 0 elements from the RT FIFO.
Sorry, I couldn't help!
07-27-2013 09:58 AM
FIFO node in RT host :] Just little trick to pull everything from the queue.
07-27-2013 07:39 PM
This is a Property Node, right? ... thanks, I'll read up on them!
07-30-2013 06:52 AM
Ok this is not a Property Node, but a Method Node, correct?
Ref: http://zone.ni.com/reference/en-XX/help/371599G-01/lvfpga/fpga_fifo_method/
Since this is for taking action on a FPGA VI, would the node be available if one is running the cRIO in Scan Mode?
