06-23-2011 10:09 AM
Hi, I am new here.
I am developing a LabVIEW code to measure real time absorbance for Ocean Optics spectrometers with OmniDriver.
I used "SetAcquisitionParameters_NET" file provided by OmniDriver sample pack for multi-spectrometers.
It is working well for normal scope mode intensity measurement with integration time, average to scan, and boxcar width. But, I do not know how to collect real time absorbance data with reference and noise data like SpectraSuite software does.
Could anyone tell me how to program this?
06-24-2011 03:16 PM
Good Afternoon,
I am not sure what your exact spectrometer is, however, there are many drivers for Ocean Optics products at ni.com/idnet. If there is a LabVIEW driver for you spectrometer here, then you can use the API within that driver to acquire the desired data. Hope this helps!
-Cody C
06-27-2011 08:10 AM
Cody C,
Good Morning. I am using S2000 and HR2000 now. I will try what you suggest. Thank you.
yoralph
06-27-2011 10:42 AM
As long as your S2000 has an USB ADD, you will be able to use it with OmniDriver-SPAM. The HR2000 will work fine.
Here are two good videotutorials that will show you how to use OmniDriver-SPAM with its LabView dll to acquire spectra:
http://spectroscopytv.com/2009/02/02/omnidriver-labview-part-1/
http://spectroscopytv.com/2009/02/02/omnidriver-labview-part-2/
Hope this helps,
R
06-27-2011 10:50 AM
Forgot to add that for the Absorabnce, you need to use or have SPAM (Spectral processing and manipulation - OmniDRiver component). http://www.oceanoptics.com/Products/omnidriver.asp
In SPAM you need to use the class: CoreAbsorbance
And the method is: processSpectrum()
Cheers,
R
01-19-2015 02:27 PM
Hello there, can u be more specific how to use the class with SPAM in labview especially to measure absorbance.
01-20-2015 10:19 AM
Please see attached example VI. In Labview 8.6, 32 bits.
Thank you,
R
06-01-2018 11:31 AM
Hi sir,,
I have tried to run this program using LabVIEW 2014 64 bits.. but it has got problem with the NetCoreAbsorbance. Should I use LabVIEW 8.6 32 bits for running this program?
Really need this info.
Thank you
10-26-2019 11:48 PM
Hi R,
Thanks for your example. I really appreciate it. Can you share another examples to calculate CCT,CRI, Purity,x,y,Ra-R14? Hope to hear from you soon.
