06-04-2009 04:42 PM
I have an analog pressure sensor that is capable of reading data at a frequency of 1K Hz. I would like to collect the pressure sensor data as a function of time at the frequency of 1K Hz (the maximum frequency for the pressure sensor). I would then like to read the pressure vs. time data in a spreadsheet.
I have been able to record the pressure vs time however the maximum frequency I am able to obtain has been ~60 Hz using the DAQ assistant(run continuously) while using the elapsed timer. I believe the DAQ assistant is running correctly, but the elapsed timer is not quick enough.
I am using a PCI-6280 DAQ board, I believe I would like to use the internal clock on this DAQ board as the timer to collect this data. I have had no luck thus far, any ideas on how to do this?
I have attached my VI for reference.
Thanks!
06-05-2009 12:25 AM
HI,
Please find attached Sanpshot, this will log the analog pressure sensor data with time (save to .xls file)
Hope this helps
Regards
Santosh
06-05-2009 02:26 PM
Thanks for your help, but I do not appear to be setting up the cluster correctly. Could you give me some advice on how to do that, or possible attach the vi, I am using Labview 7.0, but can use 8.0 is necessary.
Mike
06-05-2009 03:18 PM
06-05-2009 03:48 PM
I have have tried the suggestions, but I am still not reaching my initial goal of reading pressure vs time at a frequency of 1 KHz and exporting this to a spreadsheet. I would like to have a spreadsheet that has time values at 1 KHz, so 0.001, 0.002, 0.003, etc with the corresponding pressure values, how would I record time in this manner?
Thanks for your help thus far!
06-05-2009 04:36 PM
