Reading pressure values from Agilent IPCMINI ion pump
As it says I’m trying to read the pressure values from Agilent IPCMini ion pump controller. I’m doing this via the USB port in the back. Does anyone have experience getting the data into labview via USB?
(879 Views)
This seems the manual which discusses the protocol too: https://www.agilent.com/cs/library/usermanuals/public/IPCMini.pdf
And this is a discussion about another earlier Agilent pump but the protocol looks very similar in its structure: https://forums.ni.com/t5/LabVIEW/Serial-Communication-with-Agilent-Vacuum-Pump/td-p/3156345
And this is the link to the same question on Reddit. https://www.reddit.com/r/LabVIEW/comments/1kbtvfn/reading_pressure_values_from_agilent_ipcmini_ion/
It's proper etiquette to mention that you posted elsewhere. Otherwise you may be mistaken as an AI bot copying messages from other boards to post here for I don't know what purposes. That is real and a very annoying thing.
Rolf Kalbermatter  My Blog
(838 Views)
