10-19-2010 04:18 AM
The reading of SubVIs when opening a VI takes longer everyday.Doubled to one hour over night!!!!!!
Is there any temp folder that can be removed, any test VI for checking reading algortihms or anything else to check this?
We are using Labview 2009
It doesn't matter which account we use, thus it must be on the overall installation.
Thanks for any hints.
10-19-2010 04:32 AM
@Kilian Baur wrote:
The reading of SubVIs when opening a VI [...]
I don't really understand what "reading of SubVIs" means.....I assume that you are talking about loading times.
If you did not do it before, maybe a reboot (no hibernate or sleep!!!) can help. Another thing is a masscompile on the VI hierarchy of that VI.
If nothing helps, you have to give some figures on:
- CPU load
- Memory usage
- Steps to reproduce
hope this helps,
Norbert
10-19-2010 04:41 AM
Do you have a network path involved here, either defined in your search paths or you are obtaining the VI from a network path?
10-19-2010 05:31 AM - edited 10-19-2010 05:32 AM
We checked your hints (Norbert) but it didn't help so far. But thanks anyway.
We will check the network issue. Thanks.
