05-15-2008 09:56 PM
05-15-2008 11:37 PM
05-16-2008 12:59 AM - edited 05-16-2008 01:00 AM
Hi jeyanthi,
see the attached example picture. The constant connect to the search and replace inputs is in "code display".
Mike
05-16-2008 01:29 AM
06-03-2008 05:12 AM
hi need help .. how to remove the first line only..line(0)
i just need line (1) and above
how can it been done
06-03-2008 05:21 AM
Hi jeyanthi,
you can use the "Match Pattern" function. Search for "\n (Code Display)" and use only the string after match. Another solution is to create an array of it and remove the first line. Use the function depending on how you have the data.
Mike
06-03-2008 05:24 PM
06-04-2008 01:31 AM
