If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Reading from a text file
Naqqash_IIEE wrote:
Check this it might help. Let me know if I can help.
I have no idea why you think this would have worked. Did you actually try this? Smiley Surprised
All I can say is that if I ever want to graph the ASCII codes of each character of a string, then I know how to do it.
Message 11 of 21
(1,570 Views)
He also thought this would work.Smiley Very Happy
Message 12 of 21
(1,562 Views)
Hi Dennis,
The code works when i run it continuously and change the index row and to see it in a real time i put a delay of 0.25 seconds. However, is there a way of showing the value on the graph striaght after i press run.
Thank you.
Message 13 of 21
(1,536 Views)
Why do you keep wiring up the Index Array function that way? Do you or don't you want to read the entire file and display that? If you do, wire up the Index Array like in my example and like I already explained. What you have there does not make any sense. Even if you wanted to display one value at a time, it doesn't make any sense. Reading the same file over and over again is just silly.
Also, do not use the run continuous button!
Message 14 of 21
(1,529 Views)
Accepted by Ak star
Sorry now i have connected it correctly, but how do i change the x-aixs so i can see the graph more better.
Message 15 of 21
(1,519 Views)
No sure what 'more better' is but you can right click on the chart and select X Scale and change the style, formatting, marker spacing, etc.
Message 16 of 21
(1,508 Views)
Message 17 of 21
(1,500 Views)
I just try to help I am not a professional just like you people. I thought you people will appreciate me and try to correct and advice me instead of making fun.
Message Edited by Naqqash_IIEE on 03-04-2009 10:30 AM
Naqqash
Message 18 of 21
(1,481 Views)
Naqqash
Message 19 of 21
(1,481 Views)
Sorry you thought you were being made fun of but the code you have posted has not been close to working and you were given a correction here.
Message 20 of 21
(1,475 Views)
