Reading from CO2 sensor connected to the PC
I can see two obvious problems:
1)  You are trying to convert the VISA reference to a string instead of the data from the port you've just read.  Connect the Response string to your Scan to String VI.
2)  You forgot to connect the data out wire to your chart.
EDIT:  3)  Smiley Frustrated  I have to learn to post faster.
Message 11 of 63
(2,856 Views)
Hi GerdW
Could you maybe show me how you were thinking it should be wired? Even if I wire it to the read string it wont show anything. I am really new to labview and have very limited experience. You probably hear that alot.
Greetings
DP
Message 12 of 63
(2,849 Views)
Hi DP,
you forgot to convert your VI to LV2014 - but you already got visual suggestions you can follow…
Message 13 of 63
(2,848 Views)
I have tried to wire it as you guys has showed but it is not showing anything on the chart as mentioned earlier. Even if I do as you say. What am I doing wrong?
I attached the VI two posts ago. Would be really sweet if you could point out the error.
Greetings
DP
Message 14 of 63
(2,834 Views)
I did point out the error. See my post at the bottom of the first page.
Most importantly - TAKE SOME TUTORIALS. You would very quickly learn about some debugging techniques like using probes to see what data you are receiving etc. There are many free resources available.
(NIquist's suggestion of wiring the 'Response' to the scan from string is actually incorrect - the 'response' maintains a buffer of all of the serial data received and the scan from string will probably fail.)
(blog)
Message 15 of 63
(2,816 Views)
You are indeed correct.  I generally prefer using a shift register over the feedback node so I mis-read the functionality.  I must admit though, this is one of the places a feedback node is actually more intuitive.
Message 16 of 63
(2,814 Views)
Hey Sam
I am still learning and trying to read up on stuff as I am trying to solve specific problems. I am pretty much self taught so my knowledge is pretty limited and that is why I am trying to get help to understand how things work. I did wire it up as you suggested (see attachment) but somehow I am still not getting any data displayed on the chart.
Greetings
DP
Message 17 of 63
(2,797 Views)
Hi DP,
did you test with some probes?
What is the string reading?
Is there an error from ScanFromString?
Message 18 of 63
(2,791 Views)
Hey GerdW
Sorry for the late response. Yes, I probed and I also got an error on running (error 85) which is telling me that scan failed and that the input string does not contain data in the expected format. When I clicked the error link nothing showed up.
Greetings
DP
Message 19 of 63
(2,782 Views)
Accepted by DP123
Your first Z has a space in front of it.  That is causing error 85.
Do you really want to build up one long string of all the responses?  You are only ever going to return the first response in that long string.  You should not be using either a feedback node or a shift register in there.  Just read the data.  Use the Scan From String on the data that comes out of the VISA read, not on the build up string of data.
Message 20 of 63
(2,765 Views)
