06-23-2006 12:10 AM
06-23-2006 01:01 AM
Yes you would use a shift register to remember your array of readings
Every time you take a reading you would append the new data to array using build array in concatenate mode.
If you select a new resistor just wire and empty array to right hand side shift registor in the loop. That will reset the readings array in the following iteration of the loop.
David
06-23-2006 02:40 PM
06-26-2006 01:22 AM
It should be a while loop instead of a for loop. I would recommend that you use an event structure inside a while loop.
Take a look at the example Acquire-Analyze-Present.vi shipped with Labview. To get to the example goto Help menu then select Find Examples. Once the Example Finder is up goto the search tab and enter event. Double click event-driven. You should then see the example vi. This VI would be a great place to start.
David
