09-02-2008 11:54 PM
I am in need for ideas on how to read binary data written on a network resident text file from a windows program,not LabVIEW.
I need to read this data with a LV Vi say every 5 seconds and based on the value parse pass/fail result and data logging.
I also need to clear that binary data once read, for new data to be written by the windows program and so that LV "read" vi can get new data.
Any help truly appreciated.
Solved! Go to Solution.
09-03-2008 01:35 AM
I think u can make while loop with update control for timing, so reading in every 5 sec is not a problem but i suppose u need better synchronisation with both program execution plus network watchdog for monitoring network connection too. u can try to publish or share boolean variable controls with proper extension which ur windows platform and labview can understand, to command for ready and wait conditions plus to indicate ur network connection, so that ur program run smoothly without geting hanged.
09-03-2008 11:15 AM
09-03-2008 01:01 PM
09-03-2008 01:45 PM
