01-16-2007 10:50 PM
01-17-2007
05:11 PM
- last edited on
07-21-2025
02:57 PM
by
Content Cleaner
Hello ILJS,
Thermistors are basically resistors whose values (resistances) change with temperature. Generally a precise excitation current is applied to the thermistor and the voltage is read back. From the measured voltage and known current the resistance can be calculated (Ohm's Law) and temperature is determined. Measuring Temperature with an RTD or Thermistor is a tutorial which should help to get you started.
I recommend contacting Measurement Computing for information on using the Measurement Computing USB-1608FS.
Jennifer O.
09-07-2008 03:41 PM
Hey ILJS,
I'm trying something very similar. Were you able to succede? Please let me know what you ended up doing.
Cheers,
Murrs
09-08-2008 04:03 PM
Hello Murrs,
This is a rather old post so I am not sure if you will receive a reply from ILJS. Can I ask what hardware you are working with and what the exact application involves? I can then try and provide some recommendations.
Mallori M.
09-08-2008 08:33 PM
I am relatively new to Labview and working with DACs, btu basically I have a resistor that will change between ~500 kOhm to ~10 MOhm. I need to reliably measure this R value. For hardware I have a Laptop (Windows XP), a USB 1608FS (Measurement technologies). Now the 1608FS will allow me to measure voltage, but not current. I have no reliable current source. I guess I could put a 1 MOhm resistor in series with the variable resistance, and measure the voltage across it with a known voltage across both resistive components and back calculate the voltage drop/current.
A major limitation though is current. I'd like to stay on the uA current level, but reduce the amount of noise. I know I can do some of the noise cancelation using Labview, but I'd like a clean a signal as possible.
Any advice you may have would be appreciated.
Thanks 🙂
Murrs
09-09-2008
03:41 PM
- last edited on
07-21-2025
02:58 PM
by
Content Cleaner
Hello Murrs,
I am unfamiliar with your third party acquisition device, but if it is only capable of measuring voltage, then the Developer Zone article Resistance Measurement- Indircet Method will be very helpful. It sounds like you are on the right track though.
With regards to noise removal, much of this can be done is software post processing as you mentioned. Some suggestions for noise prevention on front end include following the suggestions in the Developer Zone article Field Wiring and Noise Considerations for Analog Signals for proper grounding of the measurement and using wires that are shielded twister pairs for all the connections.
Hope this information helps,
Mallori M
