04-28-2006 09:57 AM - edited 04-28-2006 09:57 AM
Message Edited by Tiffany_M on 04-28-2006 10:05 AM
04-28-2006 03:46 PM
04-28-2006 05:24 PM
Well, If you are using a Silabs eval board for one of their 12bit a/d micros (C8051F020), then the eval board is equiped to "speak" to the com port of the computer. What you need to do stream the 12 bit conversion out in the form a 2 bytes, look at this link's example code that uses the internal temperature sensor and the printf statement to send data to the uart port.
You could just modify this to send out a 16bit value with the upper nibble padded with zeros.
Cheers
05-10-2006 09:29 PM
