Reading 115vac 400Hz
I am working on reading 115vac 400Hz power supply using an PXI-4472.
I got it working, but if the signal gets lost the loop crashes.
How do I stop it from doing this?
Anyone got an example of reading ac voltage even if its 0volt?
kls
(4,937 Views)
You should attach your VI so people can have a look...
(4,917 Views)
I will do it tomorrow 😏
kls
(4,904 Views)
In adition to the vi, it would be interesting to know how you are reducing the 115 VAC to a level that is compatible with the PXI-4472.
steve
Help the forum when you get help. Click the "Solution?" icon on the reply that answers your
question. Give "Kudos" to replies that help.
(4,878 Views)
Accepted by Kimlorentz
Got it working.
It was my sampling settings that was wrong and how I put my code together.
For reducing 115vac i used resistors (ATTENUATOR 20:1).
OLD vi. code
New vi. code
kls
(4,851 Views)
EDIT!!
The ATTENUATOR is an 40:1 and not an 20:1.
kls
(4,804 Views)
