08-03-2020 03:08 PM
"Read and Write from text file" functions indicates that these functions do not work in a LLB.
That's exactly what I want to do that however?
First .. Is not working from a LLB true about the simple "Write to a text file" and "Read from a text file" functions?
Second- is there any way around this?
(I see the other functions within File I/O group- however they seem a little complicated at this point for me?)
Is there a simple Read and Write to text file that is compatible with LLB?
I'm using full development 2018
08-03-2020 03:13 PM
Hi chrlum,
@chrlum47 wrote:First .. Is not working from a LLB true about the simple "Write to a text file" and "Read from a text file" functions?
1. Yes, it's true. You cannot access (or create) text files inside LLB files using these functions.
2. No. Why do you need it anyway?
General comment: Using LLBs is not recommend - since several a lot of years…
08-03-2020 03:27 PM
well,
I want to record data into a text file as my program progresses through its measurement cycle.
And I really want a very simple treatment of this so what would I use?
08-03-2020 03:30 PM
Hi chrlum,
Then just use Read/WriteTextFile.
Why do you even care about "LLB files"?
08-03-2020 03:35 PM
oh pull my main VI out of the LLB and then use the rewrite file functions?
08-03-2020 03:50 PM
Hi chrlum,
Now I guess I understand your concerns…
The WriteToTextfile function can be called from a VI saved inside a LLB file, but the text file created needs to be located in an "ordinary" folder (not inside a LLB file)!
08-03-2020 03:53 PM
okay thanks I'll give it a try I'll let you know how it turns out
