Read parameters from equipment with other protocol
What you posted should work, except you should just reed thirteen bytes?
Bill
CLD
(Mid-Level minion.)
Message 11 of 19
(1,537 Views)
Hi Billko!
What do you mean when you say that?
Thank you!
Message 12 of 19
(1,502 Views)
Looks like you are reading 511 bytes.  Oh, and don't forget to close that TCP connection when you are done with it.
Bill
CLD
(Mid-Level minion.)
Message 13 of 19
(1,495 Views)
Hy!
I tried with 13 bytes and also with 511 because this equipment have 511 bytes with data! But i received error after the TCP read(with 13 bytes) "The network operation exceeded the user-specified or system time limit."
what do you think about this?
Thanks!
Message 14 of 19
(1,480 Views)
@marius.lucian wrote:
Hy!
Thanks!
I don't think it has 511 bytes, not according to the protocol.  According to the protocol, if bit 11 is 0, the expected length of the data is 4 bytes.  As per your example earlier, byte 11 in both send and receive are 0, so the send is expecting to send 13 bytes total, and you are exepcting 13 bytes total, which is exactly what your example on page 1 showed.
Your tasks, then, are:
  1. Read the first 7 bytes.
  2. From those 7 bytes, determine:
    1. Recipient address.
    2. Sender address.
    3. Parameter numbers.
      1. I would convert the bytes into an array of Boolean so you can address each bit directly.
  3. Read the amount of bytes determined by Parameter numbers bits 11 and 12.  (If bit 12 is 1, this was an error message and the following data will be 4 bytes in length.)
    1. Those bytes will be the Parameter value.
  4. Read the Checksum.
  5. Read the last byte.
  6. Calculate the actual checksum according to sections 2.1 or 2.2 as applicable.
  7. If the checksum values match, decode the values as per the manual.
Bill
CLD
(Mid-Level minion.)
Message 15 of 19
(1,467 Views)
Hy Billko!
I tried to read 7 bytes, but the "TCP read " has an error; Can you help me?
Message 16 of 19
(1,450 Views)
Accepted by marius.lucian
Hello everyone!
I find the answer! Before reading the data, needed to give it a command, meaning to write. Now it works fine!
Thank you for all your time!
Message 17 of 19
(1,437 Views)
Hello everyone!
Yes, that is the way communications with an instrument usually works.  Sometimes data is streaming, but usually you have to ask for it.
Don't forget to mark your post as the solution so people can learn from it.  If you have more questions, please create a new topic so people can plainly see this is a new issue.
Bill
CLD
(Mid-Level minion.)
Message 18 of 19
(1,435 Views)
Hy Billko!
Yes, i know this! But in the past i use the TCP protocol but I have not written a command to get an answer because i use some VI's (probably do this). TCP with ModBus Protocol.
Thank you for all answers!
Message 19 of 19
(1,412 Views)
